January 12, 2020 7:18 pm  #41
I installed the correct bearing block for the generator and got it mounted.
Had the clutch housing sandblasted and then I painted it.
Mounted the fuel pump.
and distributor.
Working on surge tank next.
January 13, 2020 2:36 pm  #42
everything is looking amazing.  I know its not factory correct but I have seen where a lot of guys strip the paint off of the serge tank,  polish them protect them with a clear coat.  They look really sharp that way
January 27, 2020 7:50 pm  #43
Took the rear end to a local shop for rebuilding.
Cleaned, sanded and painted the air cleaner.  Incidentally, if you have an OEM air cleaner I would hold on to it.  Apparently, they are becoming hard to find.  I assume that most people install an aftermarket chrome air cleaner and then toss the OEM.
Found a period correct yellow top coil from a seller on Ebay - Wild Bill's Auto.
Working on engine details. Found an NOS heat riser tube.
Cleaned and painted the coil and working on plug wires.
Getting closer.
February 1, 2020 7:17 pm  #44
Received left front suspension parts from the sandblaster and powder coater.
Sending out transmission mount to be sand blasted.
Also, finally found some Y block power steering mounting brackets. A big thanks to Windy Hill Auto Parts in New London MN. Sending them to the sandblaster too.
Finished cleaning and sanding the surge tank.
I used JB Weld Steel Stik to fill in some of the dents in the surge tank. Not concours show quality but I was happy with the way it turned out.
Surge tank painted and mounted.
Found a NOS clutch bar.
Found a place that rebuilds clutches.  I was planning on buying a new clutch but the price was just slightly more to have my original clutch rebuilt.
Now I have an original Ford Script clutch.  Too bad no one will ever know.
Working on mounting the power steering next.
February 12, 2020 3:16 pm  #45
Got the rear end back from the shop.  They didn't paint it so I did that.
After I started prepping for paint I discovered that the original Glyptal coating was still mainly intact on the third member. I deviated from my original plan and just cleaned the third member and applied clear coat on it. I think it still looks okay.
I also painted the power steering brackets and installed the power steering pump.
April 2, 2020 6:59 am  #46
Installed the left side suspension.
April 2, 2020 7:01 am  #47
Back on its wheels.
I gave in to project scope creep and decide to clean and paint a little more of the engine bay.
Started installing the rear brakes.  Thankfully I was able to send my old parking brake cables to Bruin Brake Cables and they were able to fabricate new ones using the old ones as patterns.
April 13, 2020 7:04 pm  #48
Since the car is back on its wheels I rolled her outside to take out the smelly old carpet.
Found a lot of rust on the driver's side.  I was really hoping it wasn't going to be that bad.
However, the passenger side looks pretty good.  Strange how the two sides are in such different conditions.
April 26, 2020 3:53 pm  #49
I finally gave up on the universal set of spark plug wires I got from Autozone and purchased a much better set from Napa that was pre-made.
Installed the flywheel.
Clutch
Clutch Fork
Bellhousing
I received the transmission several months ago and I'm now ready to uncrate and install it.
April 27, 2020 1:45 pm  #50
those look like some nice spark plug wire holders, where did you get them??
