January 12, 2020 7:18 pm  #41
Re: 1961 Fairlane 500 Restoration
I installed the correct bearing block for the generator and got it mounted.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sHHqVk3zj2nu4&w=800&h=600
Had the clutch housing sandblasted and then I painted it.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sbR5t1RmSZ79Y&w=800&h=600
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sn3bzEcUmiUAG&w=800&h=600
Mounted the fuel pump.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sA3Eax1LHvzma&w=800&h=600
and distributor.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sQV6PiI0ATsmU&w=800&h=600
Working on surge tank next.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0s9uOtXxpU6pSV&w=800&h=600
January 13, 2020 2:36 pm  #42
everything is looking amazing.  I know its not factory correct but I have seen where a lot of guys strip the paint off of the serge tank,  polish them protect them with a clear coat.  They look really sharp that way
January 27, 2020 7:50 pm  #43
Took the rear end to a local shop for rebuilding.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0s5DnA5B2C5xYT&w=800&h=600
Cleaned, sanded and painted the air cleaner.  Incidentally, if you have an OEM air cleaner I would hold on to it.  Apparently, they are becoming hard to find.  I assume that most people install an aftermarket chrome air cleaner and then toss the OEM.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0smKtZFN7dRMR1&w=800&h=600
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sM9M9MaPYihrn&w=800&h=600
Found a period correct yellow top coil from a seller on Ebay - Wild Bill's Auto.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sKWd8xcAxUcsu&w=800&h=600
Working on engine details. Found an NOS heat riser tube.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sHKz4nJC5bqw3&w=800&h=600
Cleaned and painted the coil and working on plug wires.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sheA5DlAdSlsZ&w=800&h=600
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0s49w0LjLbeEcF&w=800&h=600
Getting closer.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sGhTnEvacBWm9&w=800&h=600
February 1, 2020 7:17 pm  #44
Received left front suspension parts from the sandblaster and powder coater.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0swDKiYqtYBmMh&w=800&h=600
Sending out transmission mount to be sand blasted.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sZKWibFWLijuQ&w=800&h=600
Also, finally found some Y block power steering mounting brackets. A big thanks to Windy Hill Auto Parts in New London MN. Sending them to the sandblaster too.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sdLXj5kkVLG8v&w=600&h=800
Finished cleaning and sanding the surge tank.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sYyrZT42WAtbw&w=800&h=600
I used JB Weld Steel Stik to fill in some of the dents in the surge tank. Not concours show quality but I was happy with the way it turned out.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sWahEDuvXoWPr&w=800&h=600
Surge tank painted and mounted.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0svUbEjNOYlSF0&w=800&h=600
Found a NOS clutch bar.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0szaOOhwPUfVK6&w=800&h=600
Found a place that rebuilds clutches.  I was planning on buying a new clutch but the price was just slightly more to have my original clutch rebuilt.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sGoS9rcW4WWxz&w=800&h=600
Now I have an original Ford Script clutch.  Too bad no one will ever know.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0skj24sVIdMehK&w=800&h=600
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0syBDFLUOtRz5n&w=800&h=600
Working on mounting the power steering next.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sv5jPGfFAnwa5&w=800&h=600
February 12, 2020 3:16 pm  #45
Got the rear end back from the shop.  They didn't paint it so I did that.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0ssv51vbrZUdTd&w=800&h=600
After I started prepping for paint I discovered that the original Glyptal coating was still mainly intact on the third member. I deviated from my original plan and just cleaned the third member and applied clear coat on it. I think it still looks okay.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sZE0BzEskeUbF&w=800&h=600
I also painted the power steering brackets and installed the power steering pump.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0s8s4P3ENbI10M&w=800&h=600
April 2, 2020 6:59 am  #46
Installed the left side suspension.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sfvXemfgvdjmG&w=600&h=800
April 2, 2020 7:01 am  #47
Back on its wheel.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sV45umHsdWmqr&w=800&h=600
I gave in to project scope creep and decide to clean and paint a little more of the engine bay.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0s0wMPrAiZlb8c&w=800&h=600
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0stsUh1eksbpTo&w=800&h=600
Started installing the rear brakes.  Thankfully I was able to send my old parking brake cables to Bruin Brake Cables and they were able to fabricate new ones useing the old ones as patterns.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sfSAss1efEJmY&w=800&h=600
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sQq2cz3pBpxOe&w=800&h=600
April 13, 2020 7:04 pm  #48
Since the car is back on its wheels I rolled her outside to take out the smelly old carpet.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0s5bXzwESDaMZn&w=800&h=600
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sk8H3w1pGODjn&w=800&h=600
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sCzXtWj5V1f7T&w=800&h=600
Found a lot of rust on the drivers side.  I was really hoping it wasn't going to be that bad.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sWK9RozEVoiJM&w=800&h=600
However, the passenger side looks pretty good.  Strange how the two sides are in such different condition.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sA6HzhF3o0hLX&w=800&h=600
April 26, 2020 3:53 pm  #49
I finally gave up on the universal set of spark plug wires I got from Autozone and purchased a much better set from Napa that were pre-made.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sbJhjJ5IxMDAs&w=800&h=600
Installed the flywheel.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sIS3EWef1wFFT&w=800&h=600
Clutch
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sGcVQJaMQ3jG5&w=800&h=600
Clutch Fork
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sxW208Gz58TBm&w=800&h=600
Bellhousing
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sybEVwrA7Ba1t&w=800&h=600
I received the transmission several months ago and I'm now ready to uncrate and install.
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sADKWvu57jZAT&w=800&h=600
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sI8Pg7gVeb0Ew&w=800&h=600
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sZWWwFkGDdils&w=800&h=600
https://files.secureserver.net/public_file_binary.php?page_action=generate_image&hash=0sdR1hKTTptGro&w=800&h=600
April 27, 2020 1:45 pm  #50
those look like some nice spark plug wire holders, where did you get them??
