July 30, 2017 8:21 am  #1
Gravity brake bleeding
Looking for some info on how to bleed brakes simply using gravity. Never done it this way. I think I may still have some air in my system. I have bled the brakes twice, once by reverse bleeding and secondly the traditional way by pumping the brakes and opening up the bleeders one at a time.
With the gravity system...how do you go about this?
Do you open one bleeder at a time or all at once? Do you using a specific pattern...which caliper do you start and end with? How much fluid do you expect to use with this method?
Reference: 61 Galaxie, 78 Cougar front discs, 83 Lincoln rear discs, 94 1500 Chev truck master cylinder and Astrovan hydroboost.
July 30, 2017 9:47 am  #2
Re: Gravity brake bleeding
Never done it, but I would think that you would treat it like using a pump, or the old pump the pedal method by starting with the one farthest from the master cylinder and working to the closest.
July 30, 2017 12:10 pm  #3
Works really well to change brake fluid. It will help to remove some air but doesn't work very well to remove trapped air. Search for a video, lots of them on the web.
August 4, 2017 3:37 am  #4
You can search web for them
August 18, 2017 6:14 am  #5
Used to use the gravity method while I was still working. Works good. I would do 1 wheel at a time. After I assembled the wheel cylinder, brake shoes and installed the drum I would leave the bleeder open and move to the next wheel. When I saw the bleeder start dripping I would close it off. Of course you have to keep the master cylinder full. After the last wheel was finished I would bleed the system the conventional way with a helper pumping the pedal.
