February 1, 2021 5:57 am  #1
9" Rear End Leak
I just filled my 9" rear end on my project car a few weeks ago, and I noticed a small puddle of oil under it yesterday. It's leaking at the 3rd member connection. Is there a gasket between there that I might need to replace or something? The car doesn't run or drive yet, it's just been sitting there.
February 2, 2021 12:34 pm  #2
Re: 9" Rear End Leak
There is a gasket that goes between the third member and the housing and any auto parts store should have one, however I prefer RTV.  Pull the pumpkin, clean both mating surfaces then cote the pumpkin surface with a thin layer of RTV.  Reinstall the third member and tighten it down a little at a time adding a small amount to each nut, working your way around the differential.  After 3 or 4 trips around it should be tight.  Give it at least an hour to cure before adding fluid.
February 2, 2021 8:39 pm  #3
Thank you 👍
February 3, 2021 6:50 am  #4
It's always a good idea to replace the copper washers on the studs.
February 3, 2021 7:15 am  #5
I'll remember that 👍
