August 27, 2019 1:50 pm  #1
brake pedal
I've just checked with 3 of the Ford supply stores and none have  or can tell me about my brake pedal..
  It looks like it's for a power brake setup, yet my car came with manual brakes...
It is not a  removable cover but it is molded onto the metal...
I don't know if I peeled off the rubber if a "cover' will work..
  Anyone run into this?
August 28, 2019 10:45 am  #2
Re: brake pedal
What year is it?
Every car brake pedal after 1948 has a separate replaceable rubber pad.
Bill / Retired Ford Parts Manager / 1928/89 Ford Passenger Car & 1928/2001 Ford Truck ~ Part Number Research & VIN Decoding
August 28, 2019 8:14 pm  #3
Re: brake pedal
Hi
 It's a 62 Ford country sedan...   I think it's the original brake pedal, the car was pretty much
all original when I got it.  I've made changes to the engine and trans...
   Guess I need to do some research
Wait. another point is that the  pedal is removalbe from the arim...  a 3\16 or 1\4 inch bolt... holds
it in place... The pad is diffenatly  molded onto the pedal...
