June 30, 2013 10:05 am  #1
PCV Hose
Does anyone know where i can purchase the PCV hose for a 1965 Galaxie with the 352 engine?? It seems like i can find it for ever other ford engine but this one. Maybe the hose for a 390 will fit??
July 1, 2013 11:09 am  #2
Re: PCV Hose
you should be able to use any piece of rubber hose between the PVC valve and the carb
July 2, 2013 6:04 am  #3
Re: PCV Hose
All I used was the right size heater hose on the rear of my intake. It should be flexible enough unless you are wanting a very tight bend.
