June 27, 2013 8:22 pm  #1
Hey ragan64 This look a little better??
ragan64 wrote:
That looks good Daze. You did a very nice job. I did notice that your steering linkage should have "ZERO" rust issues. LOL,LOL,LOL! Don
I rebuilt the PS control valave wich was leaking teribly.  Now it may rust but at least its clean
July 3, 2013 8:52 pm  #2
Re: Hey ragan64 This look a little better??
All that work and I had to go back and redo part of it.  When I put the rebuilt valve in I replaced the ram with another one that had come with a bunch of power steering parts I had purchased on eBay.  The "new" ram looked better than my old dented up one but as I worked the rod in and out it was a little stiff.  I figured the stiffness would not be an issue and installed it, but never should have.  When I took the car for a test drive the steering was some what unresponsive as I first turned the whee then as I continued to turn the steering wheel the steering would suddenly dart in that direction.  I realized it was probably the stiff ram so I swapped it out for the old one.  Guess what the steering works great now.  I have a rebuild kit for the ram and may tare in to it, but either way the old gal is handling better than ever.
