I had to stand on my brakes yesterday and now the proportioning valve is leaking out of the plastic switch port. I don't have an idiot light connected. Thoughts on just removing it and plugging the hole? The valve itself is new. It's a 4 drum system.
69 Ford XL, 429 with a 4 speed convertible.
Thanks for any thoughts.
I'm sure others with stronger views than I have will answer, but I thought proportioning valves were only necessary on disk/drum setups. Was it installed by a previous owner? If the two reservoirs in your dual master cylinder are of the same size, I'd remove but that's me.
If you have all drum brakes it is most likely just a brake failure switch and not a proportioning valve. The brake failure switch has a shuttle that stays centered as long as the front and rear brake pressure is equal. Break a line and the pressure from the working part of the system pushes the shuttle one way or the other turning on the brake idiot light.
