March 30, 2017 6:03 am  #1
62 Galaxie 500 xl convertible
I have the above car and would like to upgrade the suspension and steering.
Anyone have any ideas as what to use?
Thanks keyma2469@aol.com
March 30, 2017 8:55 am  #2
Re: 62 Galaxie 500 xl convertible
The term "upgrade" can cover a lot of ground with respect to suspension AND steering; e.g., cost, time etc
While others, notably the site owner, can offer a boatload of insights, perhaps some goals and/or at least some of the issues you'd like to resolve?  For instance, I've found over the years that replacing worn components and ensuring the stock steering box is correctly lubricated make a world of difference.
Speaking of Daze, here's a six page thread about work on a '62 Galaxie which strikes me as covering the most extensive "upgrade" you're likely to read about.
http://galaxieforum.boardhost.com/viewtopic.php?id=466
Kevin
March 30, 2017 8:57 am  #3
Depends how deep you want to get into it?
If you want to refresh, I would go with upgrading to a 1" front sway bar and replacing worn steering components, suspension bushings, and some new shocks.
If you want to go custom, I would go with rack and pinion steering and coil over adjustable shocks. There are some threads on this forum on these modifications.
April 11, 2017 1:07 pm  #4
The upgrades mentioned above are a great jumping off point and will improve your handling quite a bit. SO will going with a rear sway bar to compliment the front.
