November 5, 2016 2:26 pm  #1
59 Galaxie seat back adjustment
Ref. my 59 Galaxie Sunliner front seat-back adjustment.  My darling wife says the front seat reclines too far back.
There are no adjusting bolts as in newer cars. Should I glue wood blocks  where the bolts would go?
The shop manual Part 17-2 shows nothing.  Please advise.
November 8, 2016 12:26 pm  #2
Re: 59 Galaxie seat back adjustment
There is no adjustment that I know of.  On my 64.5 Mustang there is a bolt that comes down out of the back and you can turn it so that it goes either in or out to adjust the seat angle.  Not a simple fix between drivers but an adjustment nun the less.  You may be able to come up with something similar.
November 8, 2016 2:08 pm  #3
I figured it out !!   I am somewhat of a packrat..dumpster diver.  I found a couple of sheet metal brackets
that fit perfectly down under the steel casting elbow...the pivot for the seat back.   I bent the brackets
making them into a smaller part 3 thicknesses totaling about 1/4" or less  The width was about 1"
The tilt of the seat back moved about 1" forward.  I can add to the shims for more adjustment.
