Hi, need to remove steering wheel 67 galaxie 500. Any ideas how to do this? Will it be easy to replace with after market one? Thanks
I posted a thread on how to remove steering wheel and steering shaft for a 61. It may give you some ideas on how yours is mounted. In the search bar on the home page, enter: "Steering shaft removal from a 61 Galaxie"
basic steering wheel puller should do the trick. remove the center cover, remove steering shaft nut, install puller and pull the wheel.
