May 26, 2016 1:11 pm  #1
Steering wheel
Hi, need to remove steering wheel 67 galaxie 500. Any ideas how to do this? Will it be easy to replace with after market one? Thanks
May 29, 2016 9:59 pm  #2
Re: Steering wheel
I posted a thread on how to remove steering wheel and steering shaft for a 61. It may give you some ideas on how yours is mounted. In the search bar on the home page, enter: "Steering shaft removal from a 61 Galaxie"
May 31, 2016 8:16 pm  #3
Re: Steering wheel
basic steering wheel puller should do the trick.  remove the center cover, remove steering shaft nut, install puller and pull the wheel.
