Hey guys I went to roll up my drivers window in my car and I believe that the rod striped out..I took off the door panel and when you turn the spliced rod your crank screws to you can watch it just spin...do I need a new regulator setup or can I just lay a small teach weld on the back of it?? As of now it's setting outside with a tarp over it in the rain.As the garage is too full to work in.Thanks Scott
Get the regulator out of the door and then you'll be able to see what is wrong with it. It can be a bit of an adventure to get the regulator out, but it will come out.
I got it out..and the internal where the gears are that the window crank goes onto..it's completely broken...I need a regulator if anyone has one
Thread Starter Offline
Get the part number off the regulator and see if you can find the interchange info. I expect there is a Master Parts Intechange Manual online somewhere, or someone can help find which cars are suitable donors.
