June 11, 2014 12:58 pm  #1
mirror glass replacment
Hello all, Im new to this forum and I am in desprate need of glass for my mirrors. If anyone knows where to find the glass for them it would be so greatly appreciated.  Thank you
June 11, 2014 1:58 pm  #2
Re: mirror glass replacment
Not sure..but while we're talking about mirrors..anyone know best adhesive for gluing my side mirror (the glass itself) back onto the mirror housing? I know rear view mirror adhesive is for metal to glass, looks like some white caulk type adhesive was used originally.
June 12, 2014 11:46 am  #3
Any reason why you could not make the patterns you need out of construction paper and then go to a glass shop and have some mirror cut to match the pattern? As far as how to glue them, I would just use silicone. We had a mirror(4feet by 7 feet) installed in a bathroom and the installer applied 8 spots of silicone about 3 inches each to the back of the mirror and then placed it on the wall. That thing hasn't moved in 15 years!
June 12, 2014 1:34 pm  #4
Presumably the car will move more than your bathroom. I think the glass shop will have good recommendations on what adhesive to use.
June 12, 2014 3:24 pm  #5
Yes, true, point taken. LOL. However, considering the weight of the mirror mentioned and the small amount of silicone used, it has demonstrated extremely good holding power. I would have no problem using silicone for the car mirror application.  An automotive adhesive is probably available or go with a two way moulding tape.
