April 13, 2014 9:18 am  #1
65 Ford Galaxie 500 Convertible Horn Ring Repair?
hello. i plan on buying a 65 ford galaxie 500 convertiblesomeone is holding for me.  the horn button/ring is broken on it. what parts would i need to fix it?  i know Dearborn Classics, Dennis Carpenter, and MAC's all sell horn parts, but i dont know the exact ices i need.
Thanks in Advance, Alice
P.S. it wont let me include a picture link yet it looks like so any ideas on how to share the pic would be apreceated.
AliceP.com
GamerGirlAlice.com
ChrisRayMemorial.com
April 13, 2014 11:32 am  #2
Re: 65 Ford Galaxie 500 Convertible Horn Ring Repair?
AliceP.com
GamerGirlAlice.com
April 13, 2014 5:47 pm  #3
Looks like the clips are broken.  if you pull the ring there should be tabs on the under side that allow it to attach to the column.  BTW welcome to the forum!!
April 18, 2014 7:47 am  #4
first wanted to say thanks for the welcome.
second i cant find plain horn clips.  all i can find that has clips on it is 2 versions of a Horn Ring Retainer Plate (Plate A & Plate B).  is one these plates the clips i need to fix the horn?
AliceP.com
GamerGirlAlice.com
April 18, 2014 8:42 am  #5
That sounds about right.  I am not as familiar with the 65 Galaxie as I am with other cars and can not say for certain with out looking at the horn ring.  Can you pull the ring and snap a picture of the under side??
May 12, 2014 7:18 pm  #6
Alice,
  Don't know if you found the part yet,  AutoKrafters has two horn ring retainers for 65 500. The part numbers are 1965 Ford Galaxie 500 HORN RING RETAINER W/ ALTERNATORPart#: D1TZ-13A809B and 1965 Ford Galaxie 500 HORN RING PLASTIC RETAINER PLATE Part#: C5AZ-13A809A.  If you have a 65 parts manual you can look up the second part # a see if it's a match.  The D1 part appears to be metal and states with altenator.  The second is a plastic one.  Hope this helps.
Dave
61 Galaxie Sunliner 390 4 Speed; 67 Fairlane 500 XL 289/C4; 68 Ford F100 6 cyl/3 Speed; 68 LeMans Convertible 350 4 Speed; 70 Lemans Coupe 350/350; 72 Ford Bronco
