January 26, 2014 3:48 pm  #1
Motor mounts
I'm building a pretty stout 390 for my 62 Galaxie and I was wondering about the motor mounts I know the 292 mounts look to be the same as the 390 mounts. They only have 2 bolts per mount the later mounts have three can I use those on my 62 . I'm a newbie by the way
1962 Galaxie 2dr hard top 292 3 speed , white with red interior ,  I building a 390 .30 with forged internals edelbrock heads cast iron headers comp hyd roller , aluminum fly wheel center force clutch tremec 3550 5 speed ,9" with 3:73 gears......
January 27, 2014 3:16 pm  #2
Re: Motor mounts
when I pulled the 352 out of my 62 and a 390 out of a 61 I parted out, both sets of engine mounts had two holes where they bolted to the block and one stud that dropped into the cradle, just like the one pictured.
