October 5, 2013 5:04 pm  #1
1962 Galaxie Radiator Core Support needed!!!!
I need a Radiator Core support for a 1962 Galazie two door hardtop. I have one, however I would like one with no rust through. Thanks
January 5, 2014 5:11 pm  #2
Re: 1962 Galaxie Radiator Core Support needed!!!!
When you say "core support" what are you refering to?
 sorry if that sounds funny, but  I have a radiator from a 62, it uses 4 bolts to hold the radiator
in place. There is the sheet metal on the bottom of the radiator, bent at 90 deg. is this
the part your talking about.
best
January 8, 2014 2:28 pm  #3
Sanddoc, he is referring to the stamped sheet metal piece that goes across front of the car.  It ties the front of the fenders and inner fenders together and is the part the radiator mounts to.
gman62, the core support on a 61 62 Galaxie (same part, not sure if the 63/64 core support is the same) is a total bolt in, you probably already knew that but the reason I mention it is if you remove yours it should be easy to patch any bad spots and make it as good as new. just a thought.  If not  I have one that I took off of a 61 that I am saving incase I ever get in a fended bender but might be willing to let it go if the offer was good enough.
