November 11, 2013 4:12 pm  #1
Speedometer cable housing 1963 Galaxie
Anyone who has replaced their transmission what length cable housing did you use, and where did you get it from?
my housing is too short.  Need a longer one.
Ford truck housing?
November 11, 2013 6:33 pm  #2
Re: Speedometer cable housing 1963 Galaxie
I was able to use the Mustang cable on my 62, I believe it is a 60" cable.  I however am running a T5 and I am not sure if it has the cable goin into the transmission in the relitavely same spot in relation to the car.  When I replaced mine the only sizes I could find were an 80" and a 60"
November 15, 2013 4:01 pm  #3
I bought a new 60" speedo cable from Summit for 20 bucks.   It seems to be longer than whats there.  It should do the trick.
November 17, 2013 6:03 pm  #4
Just a bit longer.  But all that it needed.  Bet that bend is why the speedo bounced.
