September 10, 2013 4:10 pm  #1
fuel guage
I have a 1967 galaxie and the fuel guage doesnt work. Does anyone know for sure if there is a constant voltage  regulator behind the instrument cluster?
September 14, 2013 10:10 pm  #2
Re: fuel guage
Having an early 60s Gal, I can not say for certain BUT I know for a fact that the late 60s Mustangs use one and so I am sure the Galaxies do too.  In fact it is probably the same one.
September 18, 2013 9:58 pm  #3
Re: fuel guage
Yes, but typically all of the gauges will go haywire if the CVR is bad. I suspect you have a sending unit or gauge problem. Try grounding the sending unit wire and see if the gauge moves.
1964 Mercury Montclair Marauder 2dr 390, Merc-O-Matic
1964 Galaxie 500 2dr Fastback Nascar clone
1961 Galaxie Starliner 460, C6
1961 Galaxie Club Victoria 2dr 352, 4-speed
