November 1, 2020 6:39 pm  #1
Questions about my 66 Galaxie's trim pieces.
Just removed the side trim pieces from my 66 Galaxie and had a few questions.
I thought I had broken the rear quarter letters pulling them off, but looking at them the pins were either pressed or glued into the letters. Any thoughts on remounting the pins?
https://imagizer.imageshack.com/v2/640x480q90/924/eFBilg.jpg
https://imagizer.imageshack.com/v2/640x480q90/923/sdf4Jw.jpg
Also what type of paint do I use for the 500 emblems?
One last question. The front fender badges, were they always bare metal or did they have color to them?
https://imagizer.imageshack.com/v2/640x480q90/924/r3PGgp.jpg
Thanks in advance for any help.
November 17, 2020 3:10 pm  #2
Re: Questions about my 66 Galaxie's trim pieces.
I'd guess the pins are glued in. The emblems are probably pot metal and that might make soldering, or brazing difficult. I'd try a good epoxy. On the 500 emblems a satin black paint should work. SEM makes a trim black paint that should look good. Good catylized paint and satin clear might provide longer life, but only if you have the equipment.
