October 24, 2020 2:20 pm  #1
love the satisfaction of making a tool & then having it work perfectly
The timing chain cover on my 351W is not setup for a front sump dipstick.  The boss was cast into the cover but no hole.  I have a 289 cover that has the hole but the water pump configuration is not correct for my application so I used it to fab up a fixture to drill out the hole on the 351W cover.  I had a 3/8 transfer punch that lined up my guide tube with the inside of the cover.
I originally planned on using a single guide plate but there was just enough flex that the fixture was moving when I tried to drill it out, so I had to add a bottom plate.
I drilled from the inside and this was the hole that I ended up with on the outside.
I am extremely please with the results.
October 27, 2020 6:48 pm  #2
Re: love the satisfaction of making a tool & then having it work perfectly
Very nicely done!  I wish I could do stuff like that.
October 28, 2020 1:26 pm  #3
Excellent work! Nice to see a plan come together.
