April 28, 2020 6:06 am  #1
Gas pedal push to pull
Anybody that’s done an efi swap in a 64 or earlier how did you connect the throttle cable since the 64 had a push linkage?
I have a pull gas pedal from the mustang I got the 4.6 from
But would like to retain the 64s look
1990 Crown Vic Wagon
May 20, 2020 7:38 pm  #2
Re: Gas pedal push to pull
push and pull can usually be swapped out at the throttle body.  If you look at the stock connecting point and then go to the opposite side of the pivot it will be actuated the opposite way.  Make sense?
