OK what gives.
I'm looking for Front spring isolators for my 62 country sedan, which has a 77 Ranchero lower control arm.
I've looked for both 77 and 62 isolators and can't find any.. Now if you want rear isolators. they give them away
but fronts!!! What gives
So I'm looking for 1962 upper front spring isolators
and 77 Ranchero\Torino front spring isolators...
If anyone has Info let me know
my 62 didn't come with isolators. Now that I'm running coilovers there are still no isolators. The top of the spring is direct contact to the top of the pocket.
interesting
I just bought a pair on Ebay for the 62.
I would not think they would have had metal to metal from the factory...
in my case my lower it from my 77 ranchero... which is an LTD II.
My friend ran into the same issue with his 74 super Beatle... no isolators to be found..
Guess I should look at my service manual..
I'll let you know..
Update
I just read from my 62 shop manual.. ( why didn't I just start there). OMG
and it says when removing the spring and insulator both top and bottom...
enough said...
again in my case I have a lower from the 77 Ranchero which is an LTD II. (leave it to Ford)
and the listing shows about 2015 applications...
Again Best
