I was PMed about my hydroboost in my Galaxie and figured I would make a post so everyone could benefit. Below are several reposts of the project:
on the old forum, daze wrote:
The rear drum brakes on my galaxie are locking up way to soon despite the aftermarket proportioning valve installed in line. Because of this I need to do some rear brake work. I don't see the point in investing in drums especially when I have a disc brake set up sitting on my parts shelf. Of course if I go from disc/drum to disc/disc the MC will need to be changed out. The MC I already have on the shelf for this project is a corvette unit, so that left me with two options modify the mounting holes on the corvette MC to match the Fordpattern, OR install the hydroboost unit I also have had sitting on the shelf and have planned on putting on the galaxie any way. The corvette MC will bolt directly to the hydroboost unit without modifications and special mods had to be done to mount the hydroboost to the car anyway so why modify the MC now and then they hydroboost unit mounting plate later when I can just install the hydroboost now and only modify once.
Since my Galaxie is still drivable I am getting all the parts together and ready to install first, that way the amount of time the car will be down will be minimal. I started by working out the mounting between the hydroboost and pedal assembly. I had an extra pedal assembly lying around so I had something to work with. First thing to overcome was the length of the pushrod. on my hydroboost unit the pushrod is an integrated part of the unit and was to long to
allow me to bolt the hydroboost directly to the fire wall and still hook up to the pedal. One possible solution was to cut the the rod down to size thread it and then thread on a shorter rod end. I didn't like this idea for a couple of reasons first the rod has to be narrow enough to slide inside the hydroboost unit so I couldn't cut off that much AND what would I do if I had to replace the unit down the road, modify another?? A better solution seemed to be to build a stand off
Why hydroboost you may be thinking?? well:
1. the hydraulic clutch MC on my car would have clearance issues with a normal vacuum booster unit.
2. hydroboost does not draw on engine vacuum so at idle the power brakes would be just as good as at higher RPMS.
3. hydroboost provides more brake pressure than a vacuum booster
4. unlike with vacuum power assist if the power part of the brakes were to stop due to the engine shutting off, there is no difference between
manual brake pedal effort and pedal effort (assuming the same bore MC) when going through a non functional hydroboost unit.
daze wrote:
WOW!!! I love my new hydroboost power brakes. If you want to stop, you stop right now!!
My set up consists of a mid 90s Chevy S10 hydroboost, 67 corvette master cylinder and home made lines using ends and lines from aeroquip. The power steering pump is a stock unit. I have T-bird front discs that I have had on the car for a couple of years and MarkVII rear discs that were installed as part of this project.
The project started by working on getting the hydroboost unit to be correctly spaced on the fire wall and still maintain the correct pedal height with out having to modify the hydroboost push rod. I happened to have an extra Galaxie pedal support and pedal and bolted it to my hydroboost unit to mock things up.
Once the hydroboost unit was ready to go in I turned my attention to the car and began installing the Mark VII rear discs.
With the rear discs installed I removed the old Ford master cylinder, then mounted the corvette master and the hydroboost unit in place and plumbed the brake lines.
I then added a small oil cooler to be used to keep the power steering fluid cool.
with all the pieces in place I ran the high pressure power steering lines and started on the low pressure lines. The original low pressure line from the power steering unit went to a T. The low pressure line from the hydroboust unit also went to that T and then a single line went out from the T to the oil cooler and then back to the return port of the power steering pump.
With it all hooked up, I primed and bleed the power steering system, and then tested out my new power brakes. The results were less than spectacular. When you first fired up the car the brake pedal would drop about 1/4" creating a slight brake drag. as soon as the car was turned off the pedal would come back up to normal height. Also the brakes were ultra sensitive.
I had purchased some fitting for this project from hydratech so I contacted them and told them what parts I had in my system. Shortly after I sent the email I heard back from Paul at hydratech. He was extremely helpful and new exactly what my problem was and what the potential fixes were. On a hydroboost unit too much back pressure on the return line will cause the pedal to self apply. He gave me a quick test for confirming that back pressure was indeed the issue and a list of 4 possible causes of the extra back pressure. Turns out I had all 4 and even when eliminated I still had to much back pressure. The solution was to ditch the T and add a second return line port to my power steering reservoir. To do so I took a 3/8" bolt and machined it to be a thread in nipple.
I then drilled and taped the reservoir to accept said nipple
I chose to tap the hole in the reservoir for two reasons. I wanted to be able to thread it in from inside and I wanted to be able to use RTV as a thread sealer to avoid any leaks.
From there a nut and some more RTV was applied to the outside and tightened down.
When I reinstalled the reservoir, plumbed it all back together and fired it up it performed flawlessly. In fact I am so impressed I would recommend a hydroboost unit over a vacuum assist to any one who has power steering.
older post on this forum Daze wrote:
When I set it up originally I used a Corvette Disc/Disc power MC. It worked well, I could stop on a dime but there was one small flaw. The top of the pedal pressure felt odd, not spongy like there was air in the system... but odd. It was almost like the brakes were slow to grab then after the pedal was pushed a little further they would grab no problem. The other issue I was having is if I got on the brakes hard (simulated panic stop) some fluid would push its way out of the top of the MC cover. to solve these issues I decided to get the MC from the same make and model that the hydroboost came from (94 Chevy C1500) It was a quick swap this morning, a little reverse bleeding and I was off to a test drive. I couldn't be happier with the results. the brakes were really good before but now they are 10 times better!!!!! The new MC is not as flashy as the corvette one, but I like it that way. It tones down the whole system and makes it blend in to the engine bay.
Before
After
Since I originally put this info together I have made a few more changes. I ditched the oil cooler for a transmission cooler and mounted it in front of the radiator. The transmission cooler is less restrictive and a bigger surface aria so it cools better. Doing this also helped my PS pump to run quieter. I also added a GM J-car type R&P to my Gal which required me to use a GM type II power steering pump. This had the benefit of a further reduction in noise and had no effect on breaking positive or negative.
Hi Daze, thanks for this. Question on the disc brakes, did you go with the Mark VII disc brakes for the front? And why the Mark VII, is it because they're designed for heavier cars? Thanks, Doug
Lonestar wrote:
Did you go with the Mark VII disc brakes for the front? And why the Mark VII, is it because they're designed for heavier cars? Thanks, Doug
The front discs are from an LTD II. The reason I went with the Mark VII rears is they were a fantastic junkyard option when I bought them. I got the bracket kit from a business associate of mine and put them on my Mustang. Then when I went to the Jag rear I removed the Mark VII units and put them on the Galaxie.
