January 13, 2019 1:15 pm  #1
Front spoiler/air dam for a -68 LTD?
Is there a spoiler, aftermarket or from another make, that would fit even close to a LTD/Galaxie front bumper? Or is the only choice to make it? I'd like to reduce the amount of air going unnecessarily under the car and engine bay.
LTD Country Squire -68 4.6 2V, F350 CrewCab DRW 7.3 -99
Previous: Galaxie XL Fastback -68, F150 Ranger XLT -81
January 14, 2019 10:34 am  #2
Re: Front spoiler/air dam for a -68 LTD?
I've never seen a front air dam on a stock Galaxie/LTD, certainly of that vintage. I think you'll need to custom fab something, or modify something from a different car. Either way it will be a custom piece. Are you going racing with your car?
January 14, 2019 2:50 pm  #3
Won't be racing anything. It'll reduce lift of the nose and improve stability on higher speeds and especially on windy weather. Airflow through radiator improves and there may be a marginal gain in mpg too but those are secondary.
Making one won't be a problem. The end result just depends on how much time I want to use making one from scratch rather than modifying an existing one(if one can be found with a reasonable cost).
