=13pxOk, I changed my master cylinder to a dual line power brake drum, drum master cylinder. I have power brakes from factory.
=13pxBut now The Pedal goes almost all the way to floor when running and car hardly stops.
=13pxI replaced all wheel cylinders and lines as well.
=13pxBleed brakes 3 times, but there is not much pressure when the fluid comes out of wheel,cylinder and with the top off master cylinder you can see fluid rushing back into the reservoir when you press the pedal.
Car was bought without brakes working and original Master cylinder was frozen.
