February 20, 2018 6:31 pm  #1
Searching for vent window regulator
hi all--I'm searching for a right side vent window regulator for my 1967 galaxie xl.  The gear alone would work.  Mine is apart and the gear is shredded.  Thanks.
March 16, 2018 5:09 am  #2
Re: Searching for vent window regulator
is your gear made out of aluminum?  my 63 has stripped gears and the are aluminum
August 9, 2018 8:37 am  #3
I'm searching for a 1964 Ford Galaxie driver's (LH) side vent (wing) window regulator. The first 3 gear teeth are stripped so it won't stay closed. Any help would be appreciated.
