April 21, 2018 7:57 am  #1
What is the stock voltage regulator amperage ?
Looking to buy a new voltage regulator for my 1961 Galaxie. I see there are 30,35,40 and 45 amp voltage regulators out there all saying for a 1961 Galaxie. I am going to use a stock rebuilt generator. So which one should I purchase? Which is correct or best?
April 21, 2018 12:07 pm  #2
Re: What is the stock voltage regulator amperage ?
I could be mistaken, (not that familiar with generators as apposed to alternators) but I believe in this case the "amps" is a rating and not a spec to match.  Basically a voltage regulator is a complicated switch and switches come with a max amp rating.  Its the amount of current the part will handle before it fails.  The good news is (assuming I am correct) that if you were to get the max amp regulator you would be good to go as it would handle all amos below it.
