Is there a diagram for the position of the driver's side window regulator spring - manual window. Mine fell out when I removed it from the door. Thanks for your help
It's been years, but (IIRC) on my '63, it's simply between the crank and the thin plastic "washer". Should be shaped like a Christmas tree with the crown end at the inside of the handle and the base against the door.
