Looking for the Ford part number for a slip yoke for a T-10 ,4 speed transmission from a 1963 Galaxie 390 ci.
Ok, here goes. My Galaxie was born on March 4th '63 with a 390 4barrel carb and a T-10 with 3.50:1 axle. my trans yoke is 1 1/2" dia and 8 13/64" long from end to center of joint cap. 28 spline and the part # in the 60-64 Text is
C3AZ-4841C.
There are a lot of different yokes that are very close but the spline count is 31 and length is slightly different. The outside diameter of the u joint holder is 3 15/32" wheras the 31 spline is 3 1/2" so I would make sure of your spline count before you try to find one. These yokes were used on early 63's with a 352 3 or 4 speed the 406 eng with just a 4 speed and the 390 before 6/17/63. Good luck in finding one. I would recommend Buds Classic Cars as he only specializes in 63 and 64 Ford Galaxies.
C3AZ-4841C.
Is it a counter bore design(recessed teeth in from the tube end) or NO counter bore? My spline count is 28 on my T-10
The yoke has a 2 1/2 inch counterbore.
Do you have any contact info for "Bud's Classic Cars"?
budsclassiccar.com or 1-860-738-2837. He also has a huge catalog that you will like. Order one.
