November 16, 2017 1:28 am  #1
Why Did Ford Decide to do a Flat-Plane Crank Differently?
Most V8 engine layouts are Cross-Plane (sometimes called Cruciform) due to the 4 common crank pins being positioned in two planes, 90 degrees apart. Usually the two end pins are in one plane, 180 degrees apart and the two inner pins are on a plane perpendicular to the outer’s. Figure 1 shows a typical V8 cross-plane crankshaft.
November 16, 2017 2:42 pm  #2
Re: Why Did Ford Decide to do a Flat-Plane Crank Differently?
Why did they build a flat plane crank engine? To make more power.
