July 4, 2017 7:39 pm  #1
disk brake
What would be the best front power disk brake conversion kit for a 67 Galaxie with no power drum fronts ? ...used the search  engine on website no luck .....thanks for any help
July 7, 2017 2:21 pm  #2
Re: disk brake
You should be be able to swap in spindles and disc brakes from a 69 - 71, or 72, I think, which would keep it all Ford. Look at the Scarebird kit. It uses your drum brake spindles and has a bracket that uses GM calipers, I believe. That might be places to start. Use Google to search the web for those things and see if it gets you something to work with. I'm sure you could get something from Wilwood and Baer, etc., but you may have to piece things together.
July 9, 2017 5:30 pm  #3
Re: disk brake
Wilwood has several front kits for your '67 that use your drum spindle. I have classic Series manual kit on my '68 Cougar and love it. The four piston calipers bite in and stop. Check Dearborn Classics for the power booster master cylinder setup. I believe it is around $277. They will give you the choice of drum/drum, disc/drum, it disc/disc which is nice. You might try the manual master with the classic Series wilwood. With your manual master you will have a good pedal feel, firm but not hard. My manual setup feels like my wife's Fiesta with electric power assist.
If you decide to stay manual just make sure you use a 1" or smaller bore or it will feel like your trying move a mature oak tree instead of a brake pedal.
July 9, 2017 6:50 pm  #4
Re: disk brake
thanks for the help ...been out of town
July 9, 2017 10:34 pm  #5
Re: disk brake
Good suggestions above.  Not knowing your basic strategy (driver, restomod?), something to think about as you consider options is that some "kits" require larger rims than you may have.  Of course, if you're planning on bigger wheels anyway, than that's a moot point.  And, new spindles may mean new outer tie rods, which sometimes need replacement.
Kevin
