A simple question, probably: Is it posible to remove the rear seat back, without removing the bench?
No, I think not. The seat bottom clips in, so should be easy to remove, and you remove the bottom to access the fasteners to remove the back, if I remember correctly.
As I thought. Have removed the way you describe it two times earlier. Not so easy to remove the bench, it touches the side panels. The arm rests with ash tray have to be removed. But doing it with great patience may help
I also think it is not impossible to do that because these 2 things are related to together.
like one page checkout magento 2 related magento 2 plugins and cannot separate
