I removed and rebuilt my heater and ready to re install. I have a new flexible fresh air inlet and was wondering if it is easier to install it on the heater first and fight with the mounting screws second or to mount it to the duct first and fight getting it sealed to the heater second. Either way won't be easy for me with my stiff joints. Thanks for any responses. Bud
Bud,
If you are referring to the flexible air inlet boot that goes between the heater core housing and the top of the firewall on the passenger side, you secure the boot onto the car first and then raise the heater core housing into position. There should be a large retainer/spring that secures the boot to a flange on the top of the heater core housing. The retainer ring sits on the top of the heater core housing and over the flange during installation. Once everything in position you spread the retainer ring and slide it over the boot securing it to the flange.
A tip: If you are able, secure the heater core housing on the driver side first and kind of let it hang down slightly on the passenger side so that you create more room to get your hands up there to install and secure the boot into position.
I did that job a while back, definitely not one of my more enjoyable repairs.
Thanks for the suggestions Dan, I know it is a real pain. I put the boot on the heater while I was rebuilding the heater and found it was not that easy to get on the flange lip of the heater. That's why I thought I would ask before I started cussing at my re-install. Also having a new firewall cover won't help either. Thanks again, Bud
So how did you resolve it?
