All,
I am planning to replace my fuel and brake lines - from master to drum + from tank to carburator.
I would like to know if anyone has ever done with without taking the entire body of the frame.
Is it possible to just replace the lines on a hoist/jack stands or are they not accessible without taking the body off?
Philip
The front brake lines will be the most difficult because they pass under the engine. Nothing requires body off work.
You didn't mention what model/year car you're working on but this is the most opportune time to upgrade from the fruit jar master cylinder to the dual line version in case your car is running a single line setup. There's several perfectly good methods to go about this and it's a definite step in the right direction safety-wise.
I did mangle up an expensive stainless steel "made for my car" fuel line trying to install it. It still worked but unable to get it in place without lots of bending. IMHO just buy some generic line (in sections) ...fuel and brake and bend to fit. MUCH MUCH cheaper.
I've never been able to figure out how the vendor sells and ships prebent lines with any hope of them fitting properly....... I worked for VW/Audi for over ten years and we never attempted it. All we had was rolls of tubing and bins of fittings.
Anyone try replacing metal fuel line with Fuel Line Hose? I replaced my trans cooler lines with hose and IMO it was easier and worked great.
Are you talking about fuel pump to carb? or tank to fuel pump or both?? I think a small section of hose in front of the carb for the purpose of flexing it to fit and maybe to install an aftermarket in-line filter would be acceptable. Also a short section at the tank for flex to attach to metal line. But I think replacing large sections of metal fuel line with hose may not be a good idea.
I was just thinking that new cars use nylon fuel lines/hose? Was just wondering if anyone has tried or done it.
They do, but use a lot of retainer clips and usually have a much shorter run from the tank to the engine, since modern cars are much smaller and often place the fuel tank under the passenger compartment. I would stick with steel lines on a full size car.
I used high pressure rubber fuel injection hose on my 61 with a 4.6. Both supply and return lines and also used appropriate hose clamps for high pressure application. Has been a year now, no problems.
For brake lines, I measured what I needed and purchased steel brake line with ends on. After the bends made if the line was too long I just cut and flared the end to what I needed.
