Hi. Been having trouble with fuel gauge. When key is turned on the needle goes only to the middle of the E. Could this be a bad earth problem or does it sound like the sender unit is knackered?
Could be the float has developed a leak and has fuel in it; also could be a failing sender. Grounding the sender wire should make the gauge read full IIRC; that would eliminate the gauge as the culprit. If the reading fluctuates while the key is on, look to the IVR.
Yes to the first reply, along with some relevant comments in this thread:
Kevin
