February 7, 2017 8:22 am  #1
later model ford galaxie 500
hey everybody, i recently found a galaxie 500 two door convertable at a local salvage yard. it is missing the rear axle and the carb. the intake is rusty so im wondering if the 390 is stuck. it is a later model 65-68 because it has the vertical headlights. The bodywork is pretty good id say, the rag-top is obviously shot. any suggestions on what i should look for? or what i should pay? i have no pictures for you so im sorry for that but any suggestions would be appreciated! thank you!
February 7, 2017 9:35 am  #2
Re: later model ford galaxie 500
Value is very location dependent, so you need to see what they go for in your area. However, you would expect the engine is only a core for rebuilding and it needs a rear end. You want to look closely at the frame, especially on a convertible because they tend to have more issues with water infiltration. The vertical headlight Galaxies are 65 - 67. 65 and 66 look very similar, but 67 is completely different sheet metal. FE's are expensive engines to build/rebuild and body panels can be tough to come by, but mechanical stuff should be readily available.
The real question is what do you want to do with it? I'm sure it will never be worth what you put into it, and probably by a long shot, so how much can you do yourself and where do you want to start from. If you have to put $10 - 20 K into it, how much do you want to pay to get on that ride?
February 8, 2017 7:06 am  #3
Im in highschool and with college coming up, i dont exaclty have a ton of money to be spending on this. basically id be doing some brake work, rebuilding the engine ( ive seen aftermarket rebuild 360 ford kits for 2-300$) and throwing on a rear axle and basically just getting it running and driving for the time being. the body work is pretty nice so id say i will restore it someday but for now, it would just be a ratty looking muscle car until i have the time and money to do it right.
February 8, 2017 7:10 am  #4
also, do you know what rear axles would be compatible with a galaxy? will a fairlane or a falcon axle bolt up? or even a mustang rear end? just wondering what i would need to look for
February 8, 2017 8:12 am  #5
I have just completed a convertible restoration. I spent 5 winters working on my car to get it on the road. I consider it a daily driver it is far from a show car.
If you want an honest opinion about your project...unless you are prepared to spend a ton of money and time working on it, this most likely is not a project for you at this stage in your life. I'm assuming you have not taken on a project like this before and simply may not be aware of what lies ahead regarding what you will be faced with. Restoring a car that has been sitting in a salvage yard with missing pieces is about as hard a project as it gets.
I admire your desire to own and restore a classic however. If that car is a dream car you really want to have, then you have a couple of options. Spend a little more money now and find a driver to enjoy now or buy the one you are looking at and store it until you are in a better position financially and time wise to dedicate to that project. From experience I can tell you that once you start a project you always need more money, more time and more room once you get into it.
It is not my intention to discourage you from doing this project, but rather to share my experience as I have just completed what you are contemplating starting.
Good luck with your project, all the best!
February 8, 2017 5:48 pm  #6
I admire your ambition, but would agree that a salvage yard find may not be the best way to go for a first project.
My car came from central Illinois and was purchased for $7500. In that part of the country classic cars are cheaper. The '65 I'm referring to is a 500xl has the original engine, rear , and trans after checking all of the numbers, still has the original interior, and has 44,000 documented miles.
You could easily have three times that in the car you're talking about. I'm only using mine as a reference to show that if you're patient, the deals are out there. I would gladly put you in touch with my friend who found this car as he ALWAYS seems to find solid old Ford products. He found my '68 Cougar, as well as this Galaxie and he also restores/builds cars for people.
Whatever your decision, be objective and realistic about what your looking at. If I find anything here in Georgia, I will be glad to give you a heads up. But be prepared to pay more in this part of the country. The same '65that sold for $7500 back home would be more like $10-$13000 here in Atlanta.
February 9, 2017 7:20 am  #7
alright, thank you guys. i got my hopes up for nothing, turns out it has a junked title (in wisconsin it is law that after a vehicle has a junked title, it can not be driven at all ever again) but i still have a little hope, i may take the vin number off of another galaxie and swap it over with a clean title. we will see. I will take all of your guys thoughts into consideration. ive been looking around on craiglsist. this galaxy however wouldn't be my only source of transportation. i have a 94 chevy k2500 that hauls me around and hopefully will one day haul that galaxy home
February 9, 2017 9:56 am  #8
Good luck with your search. As far as what will fit, I wouldn't bother with a Mustang, Fairlane, or Falcon. All three are much smaller cars, and a lot of them cam with the 8" rear end, which in a small block mustang, etc. would be fine, but those cars if they came with a big block used the 9" rear for a reason: Strength. To the untrained eye it is easy to mistake an 8" rear for a 9" rear as they both load the differential from the front. Also, just going by my '68 Cougar which uses many Mustang parts, the car is much more narrow. I will be glad to give you a measurement from my '65.
Also keep in consideration the following:The Mustang/Falcon rears are leaf spring rears, while the '65 on were coil sprung three link rear ends so you would also have issues with mocking up and welding the correct spring perches etc. So with that make sure the other pieces of the rear suspension are there with the car. Otherwise you will be searching for the other components as well.
I'm not trying to discourage you. I'm just trying to give you a heads up on some other things to take into consideration before you pull the trigger. You might try looking for a decent roller (car that at least has the rear end) for a first project. Or even one that is complete but needs work.
February 9, 2017 10:30 am  #9
Those master rebuild kits are typically only $2 - 300 of the $3 - 5000 in parts and labour it takes to rebuild an engine. You don't know what you need until you tear the engine down. I don't know how the title system works down there, but are you talking about trying to scam the authorities by swapping another VIN tag onto the car? That sounds risky and sketchy and may not be a good place to spend scarce resources. You will need a 9" rear end from a similar vehicle to have the width and correct suspension mounting points in the correct locations. If this car is not free, then it sounds like it is way too much.
February 9, 2017 11:26 am  #10
I agree with 70XL. I wouldn't mess around with the VIN's. You could find yourself if some real trouble if you ever got caught. Just for your information, there could be stampings of the VIN in other locations on that car. For example when I was cleaning up the frame on my 61, I discovered a VIN stamping on the top of the frame rail on the passenger side just in front of the the firewall...who knew?
