Hi. Have a 67 galaxie and need to weatherbelts fuzzies on doors. Do i have to remove glass or is there a bolt or something i can remove to drop glass down further? Any help would be appreciated. Thanks
Not sure about 67 cars, but on the 61 Galaxie there is a bracket on the inside of the door that acts as a window stop. It prevents the window from going to far into the door when you roll down your window. I replaced the window felt on my 61 and the only way was to remove the windows.
I'm hoping someone w/a '67 or a '65 chimes in because I need to do the same thing on mine.
I have a 67 convertible that i replaced the weatherstrips on it and you can lower the window by removing the lower stop bracket in the bottom of the door attached to the window. But you will not be able to remove the fizzy's with out removing the vent window assembly in order to remove the screws behind it.
Thanks for the info. Is removing the front vent easy enough to do?
Yes and No, it all depends on your mechanical ability. That being said, it can be a frustrating job or easy, it means taking your tome and noting where ever thing goes when disassembling. It would help to have a shop manual as to assist you. My way is to let the window stay in the bottom of the door as you remove the vent frame. That way you can get at the weatherstrip for removing and then replacing. After that you will wish you had another hand on your body to help. All mechanics should be born with three hands and arms to make there lives easier, ha ha ha.Hope this helps.
Very helpfull. Had visions of ripping the doors apart and ending up with glass smashed to bits. Many thanks
