June 25, 2016 11:59 am  #1
Lokar shifter
Hi guys. Has anyone had problems with lokar cable shifters? The button on the shifter is not popping up flush when in neutral. Could it be adjustment needed? On banana bracket inside or underneath near gearbox? Havent got a clue! Many thanks in advance
June 27, 2016 2:50 pm  #2
Re: Lokar shifter
I am not familiar with the shifter you mention at all, however I do have some ideas of how to trouble shoot it.  I would start by disconnecting it from the transmission.  if doing so fixes the issue than the issue is in how it installed or how it is adjusted.  if that does not fix the issue than I would start messing with the shifter and see if there was any obvious cause.
