May 28, 2016 2:42 pm  #1
1964 352 air filter and power steering fluid/transmission fluid
Hey, I am a new owner of a 1964 Galaxie 500 convertible with an original 352 engine and cruise o matic  transmission. I noticed the air filter was a NAPA gold 2083 I looked on the NAPA website and they call for a 2056. The 2083 seems to fit.  Suggestions ?  Trans/Power steering fluid type?  Type "F"  ?   Thanks, Bob
May 29, 2016 9:31 am  #2
Re: 1964 352 air filter and power steering fluid/transmission fluid
If you're buying your air filter from the local parts store, take the old one with you to compare. If ordering online, I'd go with the one you already know fits. However, make sure that it actually does fit properly and seals any air gaps between the filter and the air cleaner housing inside when the top is fastened down.
On the ATF fluid, I'd probably go with type F simply because that's what you'll have on hand and what it's probably been fed all it's life... but I really don't think it makes much difference.
May 29, 2016 11:01 am  #3
Thanks for the info.
