April 24, 2016 9:36 am  #1
Two 1967 Galaxie 500 Projects!
Howdy from Southern MO !
I have two 1967 Galaxie 500 Fastbacks. Both have clear titles in my name. Both are red with white tops and have burgundy red bench seat interiors. They both have cracked windshields, cracked & faded dash covers, and interior issues . But they have straight & solid frames, good glass & trim, and both cars are good candidates for restoration.
The first one I purchased for $1200 last fall. It's a base model 289 car with a Cruise-O-Matic, no power steering or A/C. It has a bad trunk pan but pretty good floors. The right front fender is a little crunched with a broken headlight bezel and the hood is slightly tweaked, but the rest of the body is straight with only surface rust on top.
The 18-year-old kid I bought it from bolted a bunch of go-fast goodies on a tired 70's 351 truck engine and stuck it in there, but never finished installing it properly. I have the original 289 engine but it's locked up and was sitting outside for awhile.
This car was originally purchased new at a now-defunct Ford dealership here in my home town. I tracked down the original owner, a little old lady who sold it to the kid for $1000. She was the one who dinged the front fender back in the late 70s, and around 1980 she unknowingly ran it low on oil until the engine seized up. It then sat for 35 years until the kid bought it last year.
The second car I acquired 2 months ago for $2200. This one runs & drives and is 100% complete & original down to the paint. It's also a 289 car but with factory power steering and A/C. It even has it's original steel wheels and all 4 dog-dish style hubcaps. Unfortunately the floor and trunk pans are gone and it has a couple small rust spots around the rear window and front edge of the hood. The paint still polishes out nice though, and except for the bad dash cover and one torn corner on the driver's side seat, the interior isn't too bad. The engine runs good and the tranny shifts properly, but the car rides like a boat... which isn't surprising considering the 50-year-old coil springs.
Since both cars have clear titles, I want to do frame-off restorations on both. I know, I could use one for a parts car, but all I really need to restore both are one fender & headlight bezel, 2 windshields, 2 trunk pans and one set of floor pans.
The first car will be a resto-rod and the second all original. Once I replace the windshield and check the brakes, I'll throw some temporary floor pans in the 2nd running car and drive it while I finish the 1st resto-rod one. Then I can work on the all-original car and once completed, sell it to recoup the costs of restoring both cars. That's the plan, anyway.
I haven't taken pics yet and I need to start an account on an image hosting site, but once that's done I will post pics of both cars and try to keep ya'll updated on progress. In the meantime I hope to benefit from the knowledge here and hopefully share what little I have. Glad to be here!
April 25, 2016 11:00 am  #2
Re: Two 1967 Galaxie 500 Projects!
Sounds like a great plan. A lot of work, but a great plan. You can post pictures directly to the forum, but they need to resized to smaller file sizes. Pics I post I will typically make a copy at 1200X800 size and the file size drops considerably.  Looking forward to seeing the pictures.
April 26, 2016 7:47 am  #3
Okay, well I have some pics from the Craigslist ad of the 2nd all-original car. This car was purchased new in 1967 in New Orleans and spent it's life in the Gulf Coast area up until the late 90's, when it was bought by the guy I acquired it from in northern Arkansas. That explains the rust around the rear window and front edge of the hood, salt water humidity will do that. It also explains why the frame is remarkably rust-free as it never snows down there. I'm thinking the rotten floor pans can be attributed to wet carpets, the guy in Arkansas probably left the windows open.
Notice the chickens... a true barn find.
May 1, 2016 8:53 pm  #4
Good luck with your restorations...definitely lots of work ahead dealing with two cars! The chickens look stressed the car is leaving the barn!😀😀 I'm amazed at how many old Fords I see on this forum with A/C. Being from Canada, most of the stuff that ended up here were base models with 6 bangers and three on the tree. Trying to find trim pieces and other chrome almost impossible here. Good thing for EBay! Pretty much any car I see here with options are southern cars that somebody imported at some time.
May 2, 2016 5:23 am  #5
Well I looked at quite a few '67s and this was the only one with AC. Being in southern Missouri the temps really get up there in the summer and AC is almost a necessity... we plan on a lot of weekend cruising once these cars are done so it'll come in handy.
Very few 7 liter cars around here too, most are 289s with automatics. I looked at one 390 car but the motor was seized and the rest of the car was pretty far gone. Too bad... I'll probably end up with a more modern 460 in the resto-mod, I have a '97 F350 I can pilfer the engine and E4OD tranny from, with all the AC components. A conversion from EFI to carburetors will be needed, and I'll have to figure out how to make the overdrive work without a speed sensor in the rear differential. Details.
May 2, 2016 8:56 am  #6
Sounds interesting. I just converted to EFI in my 61. If you get a chance to go thru my posts I covered lots of things you will be facing. Hope that stuff helps you out! All the best.
