April 26, 2016 1:19 pm  #1
Dual reservoir master cylinder for 63 Country Sedan
I have a 63 Country Sedan that I would like to convert to dual reservoir master cylinder. It is a manual drum brake setup.
Is there a bolt on dual reservoir master cylinder for my 63?
Thanks.
Carmak
Riverside, IA
P.S. I would like to convert to dick brakes but it is not in the cards right now.
April 27, 2016 6:27 am  #2
Re: Dual reservoir master cylinder for 63 Country Sedan
Look at a '67-ish Galaxie drum-drum master. It will bolt right up to the firewall. I used a Speedway master on my '59 and it works fine, mine is disc-drum.
