March 6, 2016 12:12 am  #1
Door handle pads, 1960...
Does anyone have a source for the outside door handle pads for a 1960 full size Ford car, Galaxie, Fairlane, etc.? Any recommendations as to a material to fabricate pads from, if they are not readily available? Thanks,  David.
March 9, 2016 11:18 am  #2
Re: Door handle pads, 1960...
When you refer to door handle pads...do you mean arm rests? If so C&G Ford Parts may have them.
March 10, 2016 8:54 pm  #3
dan 6776..... Thanks for your reply.
   By door handle pads, I am referring to the rubber/plastic pad hat goes between the outer door handle, and the car body. Sorry for not being clear for the application  in my inquiry.
   I have fabricated some pads from a cork/nitrile composition sheet.
Thanks,
David
April 13, 2016 5:34 am  #4
Late to the party, but these should be easy to find. Many Edsel and Ford door parts were the same thing.
April 14, 2016 9:40 pm  #5
BOBSS396....  Thanks. I'll continue to look for the proper pads, even though I have fabricated a set.   David.
