I am looking for a supplier of the window channel felt for a 1960 Ford Fairlane 2 door sedan (post) (full size car), rear side (quarter) window. I'm not sure that the channel on a Starliner would be able to be used in this application. The old channel has some clips/pins that align and attach the felt to the interior trim molding. The clips could possibly be reused after removing them from the old channel. Any recommendations as to a supplier of the channel? Any recommendations as to how to attach the old clips to the new channel, and keep them from dislodging? Would gluing the new channel into the trim piece be a viable option if the clips are not able to be re-used? Thanks, David.
Check out my post. Window channel liner replacement. If you enter that title in the search bar, it will bring you to the post. If you are talking about the black window felt, I also replaced that. I bought some bulk pieces, cut to length and attached with double sided automotive grade molding tape. I purchased the tape at a local automotive autobody supply store, the channel liner was purchased in a roll on line.
dan 6776.....Thanks for your reply.I'll check out your post. David.
