January 28, 2016 12:27 pm  #1
bench testing 63 and 64 am fomoco radios ..need help
does anyone have a wiring schematic they can post?? there are 4 wires on the radio,  I have 2 and trying to make one good one.  Want to bench test. Which are the speaker wires? which are pos and neg? does the unit need to be grounded at the back where the grounding strap mounts?
January 29, 2016 3:47 pm  #2
Re: bench testing 63 and 64 am fomoco radios ..need help
I will see what I can find in my 62 galaxie shop manual. probably won't be exactly the same but close. stand by
January 30, 2016 3:23 pm  #3
Blue wire red stripe is the radio light(64 electrical diagram)On my 61, two black wires coming out rear and centre are the speaker wires. They are bound together. That's 3 out of 4. I would guess the last wire is power for radio and ground is thru rear mounting bracket?
