Hi Guys, I have been doing some interior work on my 1963 Galaxie Wagon . So far I have found two partial build sheets . The first one I found was under the drivers side of the front seat about a 1/4 sheet , then under the rubber floor covering I found about a 1/3 of a sheet on the side of the transmission hump .I will look for more as I pull out the rest of the rubber matting . Anyone else find a build sheet ? if so where and in what year and model . Good luck.![]()
On my 62 it fell out when I removed the heater core box. the entire thing was there pinned between the box and the firewall.
Found mine under the rear seat partially hidden under the carpet, 61 Galaxie.
I found one taped to the inside of a door panel on one of my 62 Galaxies.
