September 6, 2015 7:20 pm  #1
What is typical OEM transmission angle in 1962-64 Galaxie?
When setting the rear end pinion angle for a 4-bar install on my 1963 Galaxie, I first checked the transmission output shaft and saw 7 degrees downward toward the rear.  It seems a bit excessive to me. It has a 390 with a C6 and a hack-job crossmember from a previous owner.  I need to fix up the crossmember before completing the 4-bar and would like to know if you guys think it should be raised a bit.  If so, what's a good target angle? - Garrett
September 7, 2015 6:12 pm  #2
Re: What is typical OEM transmission angle in 1962-64 Galaxie?
http://www.iedls.com/
Try this site out.
 There are so many variations  I would think 2 to 4 deg down but again look at the site.
September 7, 2015 6:15 pm  #3
Thanks, Sanddoc.  I'll take a look.
September 10, 2015 8:35 am  #4
In my experience most transmissions hang down about 3º  Some a little more some a little less but 3​º is a the best # to shoot for as it allows you to set your pinion at 0º because you will pick up 2 to 4 degrees from axle wrap.
September 10, 2015 10:16 pm  #5
Thanks, Daze.  Your post is consistent with what I've been hearing. I need to raise that crossmember!
