August 19, 2015 6:56 am  #1
59 Fairlane needs more whoa
I've got a 1959 Ford Fairlane Galaxie 500 that's basically bone stock. I'd like to add disc brakes and a dual master without having to 'brake' the bank.. I've got a set of front brakes, spindles, rotors, calipers, etc from a '79 T-Bird I parted out a few years ago. All were blasted and painted and ready to install on another project that took a different direction. Some sites say they're a direct bolt on, but others disagree...
Have any of you done this, or know if it'll work or not?? Thx!
August 20, 2015 2:51 pm  #2
Re: 59 Fairlane needs more whoa
Check out the following threads:  (enter in the search bar)
made a discovery as to why some cars can use LTD II spindles without...
61 Galaxie vs 77 T-Bird spindle
August 23, 2015 5:24 pm  #3
camber is the issue.  the T-bird, LTDII disc brake swap is a direct bolt on and works fantastic as far a stopping power however it is hard to get 0 camber or negative camber with these disc brakes, especially the lower the car sits.
