January 8, 2015 11:49 am  #1
1960 Sunliner oil pan
I'm attempting to remove the oil pan on a 352fe. I removed the engine mount bolts and tried to raise the engine but the whole body starts lifting and the engine doesnt seperate from the mounts. What am I missing? Everything I have read says I am doing it right. Trans and exhaust manifolds are still connected to the motor. Other than that its just the block and heads.
January 9, 2015 10:17 am  #2
Re: 1960 Sunliner oil pan
Sounds like 55 years of corrosion is stronger than the weight of the car. Try some rust penetrant and a hammer and pry bar on the engine mounts to free them up.
