Editing and cleaning this up for those searching the internet for this info. This site is not the most friendly for pics. My old pics were deleted because the URL changed no longer supported them.
Switching 63 1/2 galaxie 390 from MX cruise o matic transmission to c6 transmission. I picked a c6 from a 76 f150 ranger 360motor. Later I use a c6 from a 70 Galaxie. Both will work but the Galaxie C6 has similar shift linkage where the truck c6 has more of a downward shift and more modification is required.
The good news is that the C6 (with a round FE case) bolts up to the FE motor and that the drive shaft does not need to be modified.
Modifications are needed to the shift linkage, the passing gear shift linkage, and the cross member. The frame crossmember that supports the transmission needs to be moved further rearward. I accomplish this with thick metal braces used as adapters between the frame and the cross member. Also because the Emergency brake cables are bracketed at the cross member they need to be adjusted when the cross member moves.
Made sure the C6 has a round FE style bell housing case to mate that is mated to an FE block. ie 360, 390, 352, etc. If you're getting from a junk yard make sure to grab the flexplate, torque converter, transmisison mount, fill tube and dipstick, Cut the speedo cable and keep the speedometer gear with the trans.
Looks like the flexplate and torque converter will interchange, I kept and reused the original speedo gear from the MX/Galaxie.
The car's old coffee can starter won't fit the C6. Ordered a new starter motor. I also ordered new a C6 trans input seal, filter and gasket kit, and modulator valve. You can pick these up at any parts store.
I Cut 2 pieces 3x10 inch 3/16 plate metal and drilled holes to use as adapter plate between the crossmember and frame. this done to move the crossmember. It will end up 3 inches further back on the car. I put the C6 transmission mount (this is the short piece in between the tailhousing of the transmission and the cross member) on the car's cross member. The Truck's cross member would not fit with the exhaust pipes in the way. The transmission mount bolts won't fit well going up thru the bottom holes of the cross member but you can wiggle them in thru the sides and start w/box wrench then finish tightning w/ratchet swivel socket. The yoke from the galaxie fits into the tailhousing of the C6. The C6 is about an inch shorter than the Cruise-O but the yoke has that covered there is some play where they spline together. trans cooler lines lined up well and are same size. Dip sticks and fill tubes are NOT interchangeable. The cruise o threads on and the C6 you just shove in..has a O ring to hold in place. They are in different locations too. Looks like the thin plate..flexplate cover and dust cover interchange. Had to disassemble parking brake cable and linkage where it goes thru the cross member. I shortened the cable now that the cross member is back farther. I used cable clamps to shorten the cable.
just curious why you chose a C 6 to replace the C 4 ?
Z.
Thanks for all the info. I love all the detail. my only comment is TPNP (This Post Needs Pictures) ![]()
sorry for no pics..but busy wrenching...
Correction: use the original speedo gear if you can otherwise the speedometer will be off since the transmissons and rears are geared differently. Also the transmission cooler line did not line up like the cruise o matic but I was able to take a wrench and bend it to fit. The shift linkage will need some work. I am going back to the junkyard to look for the linkage from the C6. The Mx cruise-o-matic...(here in refered to as COM) shifter on the side of the trans housing basically moves front to rear and the C6 moves from front high to low back...so more diagonally downward. It has a slotted shift linkage that fits in a squared bolt. The COM does not.
.I have built up my 390 a little so the C6 has lots of torque to handle and I felt like it was the most bang for my buck.
A few more notes worth mentioning... the torque converter needs to be turned and pushed in 3x to get it all the way in...or else you will be wrestling with the transmission and won't be able to figure out why you can't get it to bolt up or you can't seem to get the bellhousing to flush up with the motor. Also if you do manage to bolt it up with the torque converter not completely seated your WILL destroy your pump bushing when you go to start!! Also on the torque converter ...make sure you line up the square plug with the larger hole (next to the small hole the stud goes thru) in the flexplate when you go to push your studs thru the flywheel. 15/16 socket turns the 390 crank around the get to the other torque converter studs into view. Have at least two friends and some pry bars and a transmission jack to help with getting it lined up a in.
Good luck.
g-man wrote:
"........UH.. is a cruise o matic the same as a C4?? Anyway to answer ...I have built up my 390 a little so the C6 has lots of torque to handle and I felt like it was the most bang for my buck.
The probelm with using just "cruise o matic" to ID your transmission, is that Ford used that name to refer to several completely different transmissions. And I didn't read your post close enough to rellize you were not talking about a C4. My bad.
CRUISE-O-MATIC is a marketing term. It was used from 1958 until the early seventies(?).
What people regard as a CRUISE-O-MATIC is actually the cast iron case FX, MX and HX. However, first production years of the C4 and C6 were also referred to as CRUSIE-O-MATICS by Ford. This term began being phased out with the advent of SELECT-SHIFT in 66/67.
The C4, although not used by Ford for the FE series afaik, is still a favorite with drag racers due to its durability and light weight . I think there are aftermarket bell housings that will let you use it with the FE's.
I was curious why you chose a C6 because they are well known gas hogs and horsepower black holes. They do switch out relatively easy though as you have found out. Since you bought it for a great price, it might turn out to be the most "bang for the buck" as you say, especially if you do not drive it so much that that the lower gas milage is an issue,
An FYI to others comtemplating a swaping one automatic transmission for another automatic tranmission: Most people going to the trouble of a transmission swap are tending to gravitate to the AOD, Be .sure to do plenty of research so you end up with the best choise for your specific application
Z
I believe the C6 was covered under the Cruise-O-Matic banner, basically every Ford auto trans was a Cruise-O-Matic at one time or other. As zray says, it was a marketing term, not a model, or part name. An old JY trans behind a fresh, warmed up engine is always a little risky no matter what trans it is. It may be easier to get stronger parts for the C6 over the M, F, HX, however.
My transmission was a MX judging by the pan shape and bolted on aluminum bell housing. I still lost about 50 lbs and feel like the C6 is more durable than the MX. I'll drive it to shows and cruise-ins. It's all about smiles per mile not miles per gallon so not too worried about mpg. I was able to get it to go into drive and reverse. Everything now working but have to modify shift linkage.
The vacuum modulator is on the opposite side so i ran the line up the passenger side of the trans. Will have to get a rubber vacuum line and run it over the bell housing to connect. Also the shift linkage from the truck pushed at a downward angle from the right side of steering column and connects straight to the trans. The galaxie linkage starts on the left side of the steering column goes down, over, and hinges on the block and then horizontally back to the trans. Seems to me the throw on the shifter on the side of the c6 goes down and back, but the MX moves more horizontally. So if the shift angle is to different the linkage may bind before I can get it to move to the low gears. I will report back on this. I may try and run the trucks linkage straight down to the c6 from the steering column.
You've got some fab time ahead, getting the linkage working. I remember seeing something, I think on another forum, of a guy who fabbed a swap linkage for his car. It may have been on Ford Muscle.
First image is how the original shift linkage attaches to the shifter at the firewall. The second shows a C shaped piece cut out of the left over 3/16 plate metal. This piece used to get the linkage from the truck c6 to bolt to the pass side of the steering column. (This C shaped piece was later removed when I switched back to the Galaxie linkage and a 70 Galaxie C6 transmission)
